dreet's avatar
dreet
Hub 5 and pods
Just got Hub 5 delivered as upgraded to 1gb but the 3 pods we had before don't seem to connect. Tried connecting then to router with cable but that also hasn't worked. Is there any easy fixes?
1 Reply
    Call the activation number 0800 953 9500, request the VM Pods are paired to the replacement Hub. For the call have to hand your VM a/c number, the full details from the Hub’s sticker and ALL the VM Pods.
