nockulus
5 hours agoJust joined
Hub 5 5ghz problem
I recently upgraded from Hub 4 to Hub 5 so I could take advantage of Wi-Fi 6. However my 5ghz frequency is having serious issues. It will work fine for short intervals then drop to between 0-2Mbps. When working correctly I will receive speeds up to 1100Mbps. I have tried everything I can think of and within my capabilities i.e. repositioning the router, scanning channels for interference etc. My ethernet and 2.4 ghz channel are stable and work fine. I will post all the data I have.
I receive this in logs roughly every ten minutes. Not sure what it means or if it's a problem
5ghz when working
5ghz most of the time
2.4 ghz
Any help would be appreciated.
