chronicbint's avatar
chronicbint
Hub 5 - Periodically losing LAN
Over the last year my wired connection has been failing on the Hub 5.
The wired connection will just sit at "unidentified network". No amount of reboots or reconnections will fix it.
The only way I have found to resolve this is a factory reset, It then works instantly.
This has happened around 4 or 5 times in the past year.
WiFi remains unaffacted
    When this occurs next, check the IP details of the non working devices connected to the Hub 5 for symptoms of a Hub 5 in Router mode with DHCP failure.
    When the Hub 5 DHCP fails, they have been seen to give out invalid responses to the connected devices.
    E.g.a incorrect IP address for the DNS and / or the Gateway.
    This may give the impression the Hub 5 is not responding, when in fact it has incorrectly configured your laptop or TV or as a recent case a customers building alarm.  A factory reset may fix this for a while.
    For a Hub 5 in modem mode, this issue is not present because the 3rd party router provided the DHCP service.
    • Anonymous's avatar
      Anonymous
      In Review
      If you are using the 2.5Gb port it might be network kit struggling to auto-detect/sync the line speed. Try swapping to the 1Gb port.
      I had same symptoms on Hub 5x with the 10Gb port. I remember when 100Base-TX was new having the same problem but we take it forvgrant
      • chronicbint's avatar
        chronicbint
        I have it connected to a 2.5gb switch, moving to a 1gb port would be annoying!
      chronicbint
      So what would a solution be, I did not try renewing the ip address, guess I can try that next time.
    chronicbint
    and its gone again.....gonna just buy a decent router I think.
    • Gareth_L's avatar
      Gareth_L
      Hello chronicbint.
      Thanks for your post.
      Sorry to hear about the wired connection failing.
      We have taken a look at signal levels coming into the hub and everything is perfect.
      Would you like me to arrange for a service technician to attend and see if we can swap the hub over?
      Saves you the cost of purchasing a 3rd party router.
      If you don't mind, I will need to send you a private message anyway to pass security.
      If you can check the Logo top right of your screen that would be great.
      Gareth_L
    • Gareth_L's avatar
      Gareth_L
      Hello chronicbint.
      Thanks for your private message.
      It is good to know the service is working okay now after your router purchase.
      If you need anything else, please don't hesitate to pop back on here.
      Gareth_L
    chronicbint
    I bought a WiFi 6 router to tide me over until WiFi 7 gets a bit more mainstream.
