Vim1965's avatar
Vim1965
Hub 3 wifi mode
Afternoon
This morning my Hub 3 mis behaved and I lost internet access.
It was in modem mode and doing a factory reset via the web page, the wifi did not work as a router. The Hub 3 has been in modem mode for nearly 3 years and I am using a Tenda MW6 mesh unit.
After spending most of today on the what's app chat, I have an engineer coming tomorrow ( speedy ).
Is it Hub 3 good as a modem only?
Are the Hub 4 or 5 better?
Do VM have a modem only as I am relucent to start changing all my tech ( Doorbells, camera's, hubs and the family equipment )
Your comments gratefully received
  • Well set it up in modem mode again with your Tenda
    I would suggest using a better 3rd party router with your Tenda
    any hubs are bad for wifi support some even when you setup the SSID and password just causes the hub to reset to defaults some days later best to use your own kit
