Phoenix43's avatar
Phoenix43
How I can check my average broadband usage?
I have spent ages online searching how to find out my average daily/monthly usage and also searched on the app and website and I can't find any reference to this which seems odd!
I am having a constant nightmare with Virgin, which is a separate matter, and I just need to have all the relevant information before I investigate the other matter further.
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Phoenix43
    I am so sorry that you are facing an issue with your service and thank you again for posting. Can I just clarify are you wanting to check your personal usage, as in how many devices are connected and what they are receiving, or are you looking to check the connection to the Hub?
    VM used to email me this link to usage but that link no longer works & when it did it gave one figure in Gigabytes with had no breakdown.
    VM don't appear to bother about usage unless one is saturating a the connection 24/7.
  • I can but I use my VM hub in modem mode and use my own router which gives me the stats.
