frogman's avatar
frogman
how do I order new leads for my wifi box?
Following the completion of a recent building project at my home I need to move the wi-fi box. Unfortunately the leads are embedded in a wall and I cant pull them back through without damaging them. How do I order replacement leads? I need a power cable, comms cable (the blue one) and an aerial cable (the white one)
Andy
    What exactly is this WiFi box?  Is it a Hub or a TV Box?
        It would help if you stated which Hub as they are all different and use different PSU’s.  The Ethernet cable and co-ax cables are the same.
  • jpeg1's avatar
    jpeg1
    Best plan is to book a VM technician to do the wiring for you, at a fixed price of £25.
