Joll's avatar
Joll
Having problems with broadband dropping
broadband dropping on both wifi and wired connections, also tv screen is flickering.could I have an intermitent cable fault ? Hub 3 recently change for another hub 3. Is ther a problem with hub 3s ?
Finger crossed as I know intermitent faults are difficult to find
Cheers
Peter
PS broadband dropped while posting this message
  • Check for local faults on 0800 561 0061 and ensure all cables and connections are tight and in good condition.
    • Joll's avatar
      Joll
      All internal connections are tight and were checked by engineer when visiting to replace faulty hub 3. Perhaps external connections could be at fault
      • Steven_L's avatar
        Steven_L
        Hey Joll,
        Welcome back to the community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your services at the moment. I have looked into this and cannot see anything that would be causing such issues with your connection. Are you still experiencing the issues at the moment?
        Kind Regards,
        Steven_L
