alittlemark's avatar
alittlemark
Hardwire issue - sudden loss of broadband
Morning all
I have a hub 5 with 1gig bb, connected by cat6 I have an access point in the garden and a powered 5 port switch which has my tv and my Sonos boost connected , up until Saturday at about 3 pm it’s been running fine with no issues then all of a sudden I loose everything wired bb and Wi-Fi .
reset everything and even did a hard reset and still nothing, I have disconnected everything that is hardwired and I get Wi-Fi back .
been onto Virgin and they changed the hub yesterday afternoon but with in an hour of the engineer leaving the same again no bb or Wi-Fi , so I disconnected the hardwired again and with in minutes is back.
has anyone any idea what the issue might be
many thanks
mark
    Yes, until this 2.5 Gb port is sorted for various reasons, it seems best to avoid using it.  I’ve stopped using it some time ago.
    • alittlemark's avatar
      alittlemark
      Hi guys
      it doesn’t matter what port I use as soon as I hardwire anything Wi-Fi is stopped dead along with my hardwire connection
      • goslow's avatar
        goslow
        Describe your setup in a bit more detail.
        From your description, I have read this as
        Hub 5 (Router mode inc wi-fi) >> Cat 6 cable >> Switch >> Access point + TV + Sonos
        Are you using just one Cat 6 cable to link to the switch or some different arrangement? Is the Cat 6 cable a long 'uplink' cable from the hub to a garden room or similar?
        Are you able to test one item at a time direct into the hub and see if it is any one device causing an issue?
  • legacy1's avatar
    So if you wire a PC directly to the hub its fine?
    You may need to get your own router with 1Gb ports or better and use hub in modem mode
      • John_GS's avatar
        John_GS
        Hi alittlemark
        Sorry to hear of the broadband issues and that a new router didn't fix it.
        Were you able to try hardwired direct to a PC/Laptop?
