emeraldjava's avatar
emeraldjava
Fibre Hub 1.2.1b and Port Forwarding
So I recently upgraded to 1G fibre in Ireland and not a new Hub which is running hardware version 1.2.1b and software version 3.7.4-2306.5
Having trouble with all/any port forwarding and wonder if the community here have a solution or workaround.
  • jbrennand's avatar
    As this is a UK forum... help will be limited - the VM mods wont intervene.  Some users may have suggestions for you.  What Hub type do you use?
  • You've probably been moved onto IPv6 meaning porting forwarding isn't a thing.
