Craigr2110's avatar
Craigr2110
Fibre and Media Converter
Hey all,
So a quick question, i have a fibre vroom business line, and was thinking of moving my fibre connection to my attic  where I have my server cabinet. (re terminating up there)
I have the hitron chita, so my setup is as follows.
The fibre line comes to the connection box outside, jointed to a fibre cable that comes into the house to the Fibre Modem / media converter, then to the hitron, (set to modem mode) then to my draytek, and then on to my switches.
As it stands, I would have to move the modem, and the router upstairs, as the modems output, and routers input is coaxial. Which is fine, but it just bothers me I have a lot of things plugged in before I even have connectivity.
So my question is do virgin do a modem or  media converter, that the fibre connects to with a WAN output, as opposed to coaxial, so that I could do away with the virgin router completely?
    For Residential customers VM charge only £25 for an engineer to come out on a "no fault call" to move the cables for internet  or TV  services to a different position on your building.
    Contact VM Business and see if a similar option exists.
  • jpeg1's avatar
    jpeg1
    But you will always have to use the Hitron modem.
