For the past week ive been getting persistent little spikes in packet loss and I am noticing it ingame.
Is there currently an issue in my area, no point in calling up as I never get anywhere and now the tech support has business hours so if my internet went completely off after 5pm there is nobody to call.
US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/01/2025 20:28:22
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/01/2025 16:59:25
6
Mon 13/01/2025 16:54:54
3
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/01/2025 16:32:19
6
Mon 13/01/2025 16:18:48
6
Mon 13/01/2025 14:42:00
6
US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/01/2025 14:39:15
6
Mon 13/01/2025 08:25:05
6
Mon 13/01/2025 08:00:25
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 13/01/2025 07:11:32
6
Mon 13/01/2025 07:10:24
6
Mon 13/01/2025 06:25:44
6
Mon 13/01/2025 06:21:03
6
Mon 13/01/2025 03:26:31
6
Mon 13/01/2025 03:10:50
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:21
3
Mon 13/01/2025 02:25:58
6
Engineer not long left, signal seemed fine outside so replaced the inside box thing on the wall (old one still had telewest logo on it) but upon booting up the QAM issue remains as does the original issue.
But it didn't take long for the issue to be visible again
He is going to speak with some other people to see if anything else may be going on and as last resort try changing the hub if all else fails as it could be the hub that is the issue.
Just wanted to update, looking a LOT better now in regards to the constant red dips at top and upstream channels for the moment are all on QAM64 which I have not seen in quite a while.
All it took was someone to make someone look at something other than my end.
EDIT
Not sure why but these new forums can't click for bigger image any more and can't drag image to open in new window.
