adazza's avatar
adazza
Constant Dropouts Hub 3.0 Modem Mode for a minute or so and then reconnects
Had the same issue a few years ago and engineer cam and fixed something and has been fine until recently but at different points in the day hard wired connection loses connection for a couple of minutes and then connects again. Once it starts it tends to keep doing it. Rebooting router tends to help for at least a while.
Any help gratefully received. Have tried to set up a Broadband Quality Monitor but this is 100% red. Had this working previously.
11390000000.529256 qam1
21470000000.729256 qam2
31550000000.529256 qam3
41630000000.529256 qam4
51710000000.729256 qam5
61790000000.729256 qam6
71870000000.929256 qam7
81950000000.730256 qam8
92670000002.531256 qam17
102750000002.531256 qam18
11283000000331256 qam19
122910000003.231256 qam20
132990000003.731256 qam21
143070000003.431256 qam22
153150000003.231256 qam23
163230000003.231256 qam24
17331000000331256 qam25
183390000003.231256 qam26
193470000002.731256 qam27
203550000002.731256 qam28
213630000002.731256 qam29
223710000002.931256 qam30
23379000000331256 qam31
24387000000331256 qam32
1Locked29.3-213367900927759579
2Locked29.2-184699232466207577
3Locked29.2-20967768695288178
4Locked29.51219148305280130
5Locked29.6866953184278171
6Locked29.7661862250272350
7Locked29.8197737057245425
8Locked30.1-1173444163211262
9Locked31156694810235398
10Locked31.1131497147819685
11Locked31.311379543689597
12Locked31.49148054527904
13Locked31.67854309306889
14Locked31.95735380864870
15Locked31.66304825464289
16Locked31.66384804434386
17Locked31.66976646733224
18Locked31.68209144953626
19Locked31.49610557244597
20Locked31.411698472252915
21Locked31.410284351072280
22Locked31.68638966362100
23Locked31.66159548762115
24Locked31.66150803991670
14310000046512032 qam2
23660000047512016 qam3
32360000045.5512064 qam5
43010000045.5512032 qam4
54960000047.5512016 qam1
1ATDMA00300
2ATDMA00280
3ATDMA00310
4ATDMA00160
5ATDMA00190
  • Tudor's avatar
    You have a terrible connection, a technician’s visit is probably required to rectify.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
  • Network Log
    14/01/2025 08:49:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 08:47:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 08:35:50criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 08:14:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 08:01:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:56:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:54:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:52:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:50:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:45:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:40:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:38:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:36:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:35:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:31:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:30:28criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:25:10Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:20:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:15:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    14/01/2025 07:10:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    • Tudor's avatar
