George_w's avatar
George_w
12 months ago
constant 2am Hub restarts
Please check the account associated with the IP Address of this post.
Having issues with the hub restarting between the hours of 02:00~2:30am. Strange thing is it seems to only be happening on Monday/Tuesday/Wednesday/Thursday. Other days are random. Happening for a few weeks now. At first thought it might be a firmware update issue, so performed a full hard reset, but didn't fix, carried on happening. Checked all connections inside to make sure nothing is loose.
Network logs don't seem to have any timestamps around the time it happens.
Check service status sometimes say there's an issue, check back in 24hours, then says ok, then says check back in 24hours, but never gives a reason.
12030000005.940256 qam9
22110000005.838256 qam10
32190000005.840256 qam11
42270000005.840256 qam12
52350000005.840256 qam13
62430000005.940256 qam14
72510000005.640256 qam15
82590000005.840256 qam16
9267000000640256 qam17
10275000000640256 qam18
112830000006.140256 qam19
12291000000640256 qam20
132990000006.338256 qam21
143070000006.140256 qam22
153150000006.140256 qam23
16323000000640256 qam24
173310000006.340256 qam25
18339000000640256 qam26
193470000005.840256 qam27
203550000005.540256 qam28
213630000005.540256 qam29
223710000005.940256 qam30
233790000005.940256 qam31
243870000005.640256 qam32
1Locked40.370
2Locked38.990
3Locked40.980
4Locked40.380
5Locked40.3110
6Locked40.360
7Locked40.980
8Locked40.380
9Locked40.3100
10Locked40.360
11Locked40.360
12Locked40.3110
13Locked38.9190
14Locked40.370
15Locked40.3100
16Locked40.3100
17Locked40.350
18Locked40.380
19Locked40.370
20Locked40.380
21Locked40.3100
22Locked40.3100
23Locked40.360
24Locked40.380
12360003042.3512064 qam11
23659999543.3512064 qam7
33010000042.8512064 qam8
44310000043.8512064 qam6
54960000044.5512064 qam5
1ATDMA0010
3ATDMA0000
4ATDMA0000
5ATDMA0000
01/01/1970 00:01:45criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
21/07/2024 13:20:59ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
17/07/2024 23:20:5noticeLAN login Success;CM-QOS=1.1;CM-VER=3.0;
14/07/2024 16:47:14criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
14/07/2024 13:05:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
12/07/2024 00:28:16noticeLAN login Success;CM-QOS=1.1;CM-VER=3.0;
12/07/2024 00:27:29Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-QOS=1.1;CM-VER=3.0;
05/07/2024 22:44:33criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
04/07/2024 17:45:2noticeLAN login Success;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:44criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
04/07/2024 17:00:45noticeLAN login Success;CM-QOS=1.1;CM-VER=3.0;
02/07/2024 04:56:56criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
01/07/2024 19:04:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-QOS=1.1;CM-VER=3.0;
29/06/2024 02:48:2criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
28/06/2024 07:04:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-QOS=1.1;CM-VER=3.0;
25/06/2024 10:47:45criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
24/06/2024 19:04:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-QOS=1.1;CM-VER=3.0;
22/06/2024 14:02:1criticalNo Ranging Response received - T3 time-out;CM-QOS=1.1;CM-VER=3.0;
  • fizz's avatar
    fizz
    Fibre optic
    Yes it has the same days Tuesday Wednesday Thursday at 2am... however not last night I have had this before strangely no discussions this time and no advice. last time was September and STILL nobody has replied on my post about this that is two weeks old... in September I had to have an engineer out to do nothing other than raise it with networks as you can't.....
    • Tom_W1's avatar
      Tom_W1
      Hi fizz thanks for your reply here.
      If you've mentioned it's been resolved now that's great news! Please let me know if you need any further help 😊
      Many thanks
  • fizz's avatar
    fizz
    Fibre optic
    I had Thursday with nomrrboot can't say it is resolved yet as I had this before started again the following week...
  • fizz's avatar
    fizz
    Fibre optic
    Btw how do I let you know as I can't tag anyone....
    • Sabrina_B's avatar
      Sabrina_B
      Hi fizz.
      Thanks for the update on this, you can tag a user with the @ and their name so fizz. Can we ask what further assistance do you need?
      Sabrina
  • fizz's avatar
    fizz
    Fibre optic
    .@Sabrina_B well nothing now but nobody even looked at my thread about the 2am reboots that I raised three weeks ago but I had plenty of replies to this one This stopped last Thursday..
    • Carley_S's avatar
      Carley_S
      Glad to hear that this seems to be resolved for you now.
      We would try and keep support within one thread, so if you've started being supported on another thread we'd look to keep that support within one area to save any confusion, repeated questions and multiple requests.
      Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed.
