pokerspace's avatar
pokerspace
connection problem, bad ping and red light
my connection is poor, ie dropping connection, ping all over the place and the red light on the modem always on, its an old hub 3 and I use it in modem mode as I have my own router, I have tried all the usual on and off and a reset, I have tried to speak to a virgin media rep a few times about this and was not a great experience, I have been putting up with this for too long now and need you to please organise a new hub or I will need to cancel this service and seek a replacement
  • jbrennand's avatar
    When the hub3 is in modem mode the light is "Magenta" - which can look red to some eyes - particularly if the LED is 'old". Flick the hub back into router mode fr a minute and the light should turn white.  Or... on older hubs it can fade to beige>yellow>orange>red.  It is no indicator of any connection issues.  Are yours wifi only - or on ethernet cable connected devices too?
    Lets see if we can spot any issues - do this...
    Post up your Hub/network connection details in the format below and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
  • Hi John
    have switched to router mode to see if the light stayed red, think it was white and then turned green when I had laptop plugged in, we use a mixture of ethernet and wireless connected to an asus rog rapture gt-ac5300 router which is a great piece of kit but of late we are experiencing a few issues, which seem to be getting more frequent across the whole network with i.e. slow connections, no connection and ping latency within games jumping up and down to the point of disconnection. I do have the broadband monitor and have just started to monitor the connection as it wasn't working due to the ICMP echo not enabled within my router settings. hub3 logs in next message
  • Cable Modem Status
    Status
    Downstream
    Upstream
    Configuration
    Refresh data
    1 139000000 -4.5 38 256 qam 1
    2 147000000 -4.7 38 256 qam 2
    3 155000000 -4.5 38 256 qam 3
    4 163000000 -4.4 38 256 qam 4
    5 171000000 -5 38 256 qam 5
    6 179000000 -5.5 38 256 qam 6
    7 187000000 -5.5 38 256 qam 7
    8 195000000 -5.2 38 256 qam 8
    9 203000000 -5.9 38 256 qam 9
    10 211000000 -6.7 38 256 qam 10
    11 219000000 -7.2 38 256 qam 11
    12 227000000 -7.2 38 256 qam 12
    13 235000000 -7 38 256 qam 13
    14 243000000 -7.5 38 256 qam 14
    15 251000000 -8.2 38 256 qam 15
    16 259000000 -8.2 38 256 qam 16
    17 267000000 -7.9 38 256 qam 17
    18 275000000 -8.5 37 256 qam 18
    19 283000000 -9.4 37 256 qam 19
    20 291000000 -9.9 37 256 qam 20
    21 299000000 -9.2 37 256 qam 21
    22 307000000 -8.7 38 256 qam 22
    23 315000000 -8.5 38 256 qam 23
    24 323000000 -9 37 256 qam 24
    1 Locked 38.9 88 54
    2 Locked 38.9 169 65
    3 Locked 38.9 107 155
    4 Locked 38.9 133 54
    5 Locked 38.9 102 40
    6 Locked 38.9 116 49
    7 Locked 38.6 90 56
    8 Locked 38.9 76 72
    9 Locked 38.9 99 54
    10 Locked 38.9 127 52
    11 Locked 38.6 178 49
    12 Locked 38.9 154 51
    13 Locked 38.9 133 54
    14 Locked 38.6 204 46
    15 Locked 38.6 195 36
    16 Locked 38.6 447 46
    17 Locked 38.6 168 36
    18 Locked 37.6 1034 38
    19 Locked 37.6 2608 50
    20 Locked 37.6 932 44
    21 Locked 37.6 253 36
    22 Locked 38.6 103 50
    23 Locked 38.6 115 36
    24 Locked 37.3 182 38
    Cable Modem Status
    Status
    Downstream
    Upstream
    Configuration
    Refresh data
    1 23600000 45.8 5120 64 qam 5
    2 36600000 47.3 5120 64 qam 3
    3 30100000 46.5 5120 64 qam 4
    4 43100000 46.5 5120 64 qam 2
    5 49600000 48.3 5120 64 qam 1
    1 ATDMA 0 0 0 0
    2 ATDMA 0 0 0 0
    3 ATDMA 0 0 0 0
    4 ATDMA 0 0 0 0
    5 ATDMA 0 0 0 0
    Cable Modem Status
    Status
    Downstream
    Upstream
    Configuration
    Refresh data
    11/11/2024 11:36:10 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/11/2024 11:35:11 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:33:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:33:14 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:32:59 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:32:59 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:32:53 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    01/01/1970 00:01:45 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:27:22 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:27:21 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:23:47 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:23:47 Error Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:21:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:21:42 Error Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:19:39 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:19:38 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:19:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:19:4 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:18:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    09/11/2024 21:18:27 Error Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
        I dont do logs 😂
        But your down power levels are all  very low - minimum recommendation is -6 dBmV - many of your channels are well below that and will need a Tech visit to adjust back into range.  A VM Person will respond here soon
        You also have post RS errors - you shouldnt have - so...
        Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, Do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Disconnect all the connections and reconnect to be sure. Ensure there are no “unterminated cable loose ends. Also check that the internal wiring is ok with no kinking, chaffing or dog chews etc.
        Also, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then, switch the Hub back on and leave ~5 minutes
        When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
  • I will keep the broadband monitor running to catch any issues as it seems to be running fine atm
