360Petty's avatar
360Petty
4 months ago
Connection drops...
Hi all
Back again with another issue of the dreaded connection drops. I was working from home yesterday and rebooted as soon as it drops but when I don't reboot the connection doesn't recover so something going on. Can't say what though as the logs don't mean much to me, I have checked all of the connections in the house and everything is really tight, the only thing that I can think of is some electrical work done and the power was cycled a few times, but not sure why that would result in this.
It also suspiciously looks like the connection drops 2 hourly although the 10am drop was a little early.
Any ideas?
thinkbroadband.com BQM
TimePriorityDescription
14-10-2025 08:16:05noticeGUI Login Status - Login Success from LAN interface
14-10-2025 08:15:47noticeGUI Login Status - Login Fail from LAN interface
14-10-2025 07:17:40warningDynamic Range Window violation
14-10-2025 07:17:40warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;[REMOVED]
14-10-2025 07:17:39warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;[REMOVED]
14-10-2025 07:17:37noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2 3; New Profile: 1 2.;[REMOVED]
14-10-2025 07:07:30noticeUS profile assignment change. US Chan ID: 14; Previous Profile: 13; New Profile: 11 13.;[REMOVED]
14-10-2025 07:07:30warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;[REMOVED]
14-10-2025 07:06:56noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;[REMOVED]
14-10-2025 07:06:33noticeREGISTRATION COMPLETE - Waiting for Operational status
14-10-2025 07:06:28warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;[REMOVED]
14-10-2025 07:06:28warningDynamic Range Window violation
14-10-2025 07:06:27warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;[REMOVED]
14-10-2025 07:06:27warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;[REMOVED]
14-10-2025 07:06:27warningDynamic Range Window violation
14-10-2025 07:06:27warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;[REMOVED]
14-10-2025 07:06:22noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;[REMOVED]
14-10-2025 07:06:18noticeTLV-11 - unrecognized OID;[REMOVED]
14-10-2025 07:06:16warningDHCP WARNING - Non-critical field invalid in response ;[REMOVED]
14-10-2025 07:06:14noticeHonoring MDD; IP provisioning mode = IPv4
14-10-2025 07:06:05criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;[REMOVED]
14-10-2025 07:06:03criticalCable Modem Reboot because of - HW or Power-On Reset
13-10-2025 22:09:05criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;[REMOVED]
13-10-2025 22:08:56criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;[REMOVED]
13-10-2025 22:08:28criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;[REMOVED]
13-10-2025 22:08:26criticalCable Modem Reboot because of - Reboot UI
13-10-2025 20:03:03criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;[REMOVED]
13-10-2025 20:02:29criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;[REMOVED]
13-10-2025 20:02:28criticalCable Modem Reboot because of - HW or Power-On Reset
13-10-2025 17:56:06criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;[REMOVED]
13-10-2025 17:55:58criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;[REMOVED]
[MOD EDIT: Private information removed]
    • Martin_N's avatar
      Martin_N
      Hi 360Petty,
      Thank you for your post. We're very sorry to hear about the issues you've had with your broadband service.
      We can certainly take a look into this for you to see what can be done to help.
      I will private message you now to confirm your details.
      ^Martin
  • 3.0 Downstream channels
    Channel
    Frequency (Hz)Power (dBmV)SNR (dB)ModulationChannel ID
    12910000007.241QAM 25620
    21390000007.540QAM 2561
    31470000007.540QAM 2562
    41550000007.440QAM 2563
    51630000007.440QAM 2564
    61710000007.240QAM 2565
    7179000000740QAM 2566
    8187000000740QAM 2567
    9195000000740QAM 2568
    102030000006.840QAM 2569
    112110000007.140QAM 25610
    12219000000739QAM 25611
    132270000006.840QAM 25612
    142350000006.540QAM 25613
    152430000006.440QAM 25614
    162510000006.440QAM 25615
    172590000006.741QAM 25616
    182670000006.941QAM 25617
    192750000007.141QAM 25618
    202830000007.141QAM 25619
    212990000007.241QAM 25621
    22307000000741QAM 25622
    233150000006.939QAM 25623
    243230000006.940QAM 25624
    253310000006.941QAM 25625
    26339000000741QAM 25626
    27347000000741QAM 25627
    28355000000741QAM 25628
    29363000000841QAM 25629
    3037100000011.741QAM 25630
    3137900000011.642QAM 25631
    323870000009.242QAM 25632
    Channel
    Locked StatusRxMER (dB)Pre RS ErrorsPost RS Errors
    1Locked4100
    2Locked40240
    3Locked4010
    4Locked4030
    5Locked40180
    6Locked4060
    7Locked4000
    8Locked4000
    9Locked4050
    10Locked4010
    11Locked4000
    12Locked3900
    13Locked4000
    14Locked4020
    15Locked4000
    16Locked4000
    17Locked4100
    18Locked4100
    19Locked4100
    20Locked4100
    21Locked4100
    22Locked4100
    23Locked3900
    24Locked4000
    25Locked4100
    26Locked4100
    27Locked4100
    28Locked4100
    29Locked4100
    30Locked4100
    31Locked4200
    32Locked4200
    3.1 Downstream channels
    ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
    159944K1840QAM 40961108
    Channel IDLocked StatusRxMER Data (dB)PLC Power (dBmV)Corrected errors (Active Profile)Uncorrectable errors (Active Profile)
    159Locked01.25399175253
  • 3.0 Upstream channels
    Channel
    Frequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
    04960000042.55120QAM 649
    14310000041.55120QAM 6410
    236600000415120QAM 6411
    33010000040.55120QAM 6412
    42360000040.55120QAM 6413
    Channel
    Channel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
    0ATDMA0100
    1ATDMA0100
    2ATDMA0100
    3ATDMA0100
    4ATDMA0100
    3.1 Upstream channels
    ChannelChannel Width (MHz)Power (dBmV)FFT TypeModulation
    141036.72KQAM 256
    ChannelChannel TypeNumber of Active SubcarriersFirst Active Subcarrier (Hz)T3 TimeoutsT4 Timeouts
    14OFDMA2007400000000
    Check for known faults in your street. Try both methods:
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    Check the Service Speed:
    https://real-speed-fe.eu1.sk.thousandeyes.com/
    Once the test begins click on: Run full test
    to include: Latency, Jitter, Packet loss & Upload speed
    The speed at the Hub should reflect your subscription.
    • 360Petty's avatar
      360Petty
      Thanks for the reply
      Speed wise it's short of the 1Gbps but the upload is where it should be.
      Channel
      Channel
      1Locked4100
      2Locked40240
      3Locked4010
      4Locked4030
      5Locked40180
      6Locked4060
      7Locked4000
      8Locked4000
      9Locked4050
      10Locked4010
      11Locked4000
      12Locked3900
      13Locked4000
      14Locked4020
      15Locked4000
      16Locked4000
      17Locked4100
      18Locked4100
      19Locked4100
      20Locked4100
      21Locked4100
      22Locked4100
      23Locked3900
      24Locked4000
      25Locked4100
      26Locked4100
      27Locked4100
      28Locked4100
      29Locked4100
      30Locked4100
      31Locked4200
      32Locked4200
    Seeing the Downstream and Upstream signal / error levels may be more informative.
