ghiggz's avatar
ghiggz
29 days ago
Connection dropping daily since speed upgrade
I have been with Virgin for about 4-5 years and it has generally been fine in that time.
So when my contract was recently up last month, I renewed and also haggled a cheap speed increase from 250 to 350..
Since then its been dropping out multiple times a day, every day, and being a right pain...
The system checker never shows any faults in my area, and when accessing the hub it identifies the signal is down but offers no solution.
The Hub light will either go red or flash yellow. Sometimes it will come back itself after 5-10 mins, other times it wont come back until I reboot the hub.
Then maybe an hour later its off again.. or sometimes 6 hours later..
Have checked all connections multiple times...
This is the log just after it went off if it makes any sense to anyone??
  • Engineer came out last night, said our signal is terrible around -9 to -10.
    Its only been playing up since we added on TV last month, he said the tv box drops it another 4-5dbmv when split so it was probably just within the threshold for years and soon as we added tv that weakened it too much...
    There are also loads of faults in our cabinet which has been passed to neworking, he struggled to find a spare feed thats stronger. In the end they did something the other end boosted it I dunno, and he got it up to a decent level.
    Giving it a try for a few days, he said the only other thing to try if it keeps up is a plug in booster that sits in front of the splitter that gives +10 to the signal....
  • Not speed issues, when its working the speed is great, its reliability issues..
    This was yesterdays graph....
    Just thought after 5-6 years of being fine we only started having issues when we recently added TV and I was sent a TV box. Will that be causing anything??
    i now have an appt for an engineer to come out 13/06..
    Unless there is a 10dB wideband attenuator that can be removed from the coax to the Hub 5,
    phone in and request and engineer corrects the signal levels.
    • ghiggz's avatar
      ghiggz
      Is closer to zero 'better' for the levels?? I factory reset the hub this morning, it hasnt helped with the drop outs as its still going off but the levels have dropped from in the 9's to in the 7's..
      • Matthew_ML's avatar
        Matthew_ML
        Glad to hear there has been some processed on this for you.
        Please do keep us updated.
  • Its gone off several times today..
    my son is home trying to finish his college report and it keeps cutting him off...
    can someone from Virgin advise, or book an engineer... thanks..
    • ghiggz's avatar
      ghiggz
      Wasnt too bad yesterday, but dropping a lot again this morning..
      It just went off again and I have been on the system checker on the app and now its saying I need to book an engineer, so have done that...
    • ghiggz's avatar
      ghiggz
      This is todays, its gone off several times..
      can someone from virgin please advise, or book and engineer to visit??
      Its going down 6-10 times a day every day..
      thanks.
      [Mod - image removed due to IP address]
  • It went off again earlier so I checked online and rang the number and both said no issues in my area...
    The hub went flashing red, after ten mins I rebooted it and it was flashing yellow, took about 15mins to come back on...
    this is the hub data as it was off....
    3.0 Downstream channels
    Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
    1     419000000      -9.5       38    QAM 256    36
    2    203000000    -8.9    38    QAM 256    9
    3    211000000    -9    38    QAM 256    10
    4    219000000    -9.1    38    QAM 256    11
    5    227000000    -9.2    38    QAM 256    12
    6    235000000    -8.9    38    QAM 256    13
    7    243000000    -9.1    38    QAM 256    14
    8    251000000    -9.5    38    QAM 256    15
    9    259000000    -9.2    38    QAM 256    16
    10    267000000    -9.1    38    QAM 256    17
    11    275000000    -9    38    QAM 256    18
    12    283000000    -8.8    38    QAM 256    19
    13    291000000    -8.7    38    QAM 256    20
    14    299000000    -8.9    38    QAM 256    21
    15    307000000    -9.2    38    QAM 256    22
    16    315000000    -9    38    QAM 256    23
    17    323000000    -9.5    37    QAM 256    24
    18    331000000    -9.4    37    QAM 256    25
    19    339000000    -9    37    QAM 256    26
    20    347000000    -9.1    37    QAM 256    27
    21    355000000    -9.1    37    QAM 256    28
    22    363000000    -9    38    QAM 256    29
    23    371000000    -9.1    38    QAM 256    30
    24    379000000    -9.4    37    QAM 256    31
    25    387000000    -9.8    37    QAM 256    32
    26    395000000    -9.8    37    QAM 256    33
    27    403000000    -9.9    37    QAM 256    34
    28    411000000    -9.7    37    QAM 256    35
    29    523000000    -9.7    38    QAM 256    37
    30    531000000    -10    37    QAM 256    38
    31    539000000    -9.3    38    QAM 256    39
    32    547000000    -9    38    QAM 256    40
    Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
    1    Locked    38                                                              101859    37426
    2    Locked    38                                                              44826    8431
    3    Locked    38                                                             40766    8366
    4    Locked    38                                                            96046    31265
    5    Locked    38                                                             66023    17147
    6    Locked    38                                                            103206    39854
    7    Locked    38                                                             93105    32346
    8    Locked    38                                                           85721    28269
    9    Locked    38                                                           90398    29715
    10    Locked    38                                                            76809    21099
    11    Locked    38                                                             93920    27535
    12    Locked    38                                                            462031    40386
    13    Locked    38                                                              53046    17610
    14    Locked    38                                                              37135    18492
    15    Locked    38                                                             89024    37704
    16    Locked    38                                                             84070    28377
    17    Locked    37        58268    10042
    18    Locked    37        59400    12007
    19    Locked    37        60887    18335
    20    Locked    37        58836    11490
    21    Locked    37        55481    11372
    22    Locked    38        50080    9737
    23    Locked    38        47388    8793
    24    Locked    37        45393    8411
    25    Locked    37                                                               52274    9079
    26    Locked    37                                                               57849    9204
    27    Locked    37        59593    7286
    28    Locked    37        61444    11151
    29    Locked    38                                                               26445    6932
    30    Locked    37        26596    6806
    31    Locked    38        22978    4413
    32    Locked    38        24434    6548
    3.1 Downstream channels
    Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
    159    94    4K    1840    QAM 4096    1108
    Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
    159    Locked    39    -8.7    2550199201    99334
    3.0 Upstream channels
    Channel    Frequency (Hz)    Power (dBmV)    Symbol Rate (ksps)    Modulation    Channel ID
    0    49600000    56.5    5120    QAM 64    9
    1    43100000    56.5    5120    QAM 64    10
    2    36600000    56    5120    QAM 64    11
    3    30100000    55.5    5120    QAM 64    12
    4    23600000    55.5    5120    QAM 64    13
    Channel    Channel Type    T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
    0    ATDMA    0    72    0    0
    1    ATDMA    0    72    12    0
    2    ATDMA    0    72    0    0
    3    ATDMA    0    72    0    0
    4    ATDMA    0    72    0    0
    3.1 Upstream channels
    Channel    Channel Width (MHz)    Power (dBmV)    FFT Type    Modulation
    14    10    50.5    2K    QAM 256
    Channel    Channel Type    Number of Active Subcarriers    First Active Subcarrier (Hz)    T3 Timeouts    T4 Timeouts
    14    OFDMA    200    74000000    0    0
    General Configuration
    Network access    Allowed
    Maximum Number of CPEs    1
    Baseline Privacy    Enabled
    DOCSIS Mode    3.1
    Config file    834ncxv9873254k;fg87dsfd;
    SFID    618
    Max Traffic Rate    402500089 bps
    Max Traffic Burst    42600bytes
    Min Traffic Rate    0 bps
    Primary Upstream Service Flow
    SFID    617
    Max Traffic Rate    38500089 bps
    Max Concatenated Burst    42600bytes
    Scheduling Type    Best Effort
    [Mod edit: MAC details removed]
    • legacy1's avatar
      upstream power to high lots of timeout and downstream power too low
    Also, Post the power levels, Pre and PostRS errors and network log from the Hub.
    Setup a BQM to monitor your circuit www.thinkbroadband.com/ping
    Run a wired speed test on www.samknows.com/realspeed and post the results.
    Once done we can comment.
