chrispy1's avatar
chrispy1
Up to speed
3 months ago
Connecting to WiFi Pod
I have a security camera in my shed with a very weak connection. There’s also a pod in the shed, but instead of connecting to it, the camera connects to the hub in the house over 20 feet away. Is there a way to get the camera to connect to the pod?
    AFAIK there is no management software for the Pods that allows such granular control.
  • Roger_Gooner's avatar
    Roger_Gooner
    Try rebooting the camera, moving the pod slightly or temporarily turning off the Hub’s 2.4 GHz band so the camera has to join the pod. Once it’s connected, you can turn 2.4 GHz back on.
    If you have a white pod and if the shed has power, try a powerline adapter instead which might well be far superior in producing a Wi-Fi signal especially if the shed and the house share the same ring circuit, the same breaker and the same phase.
    The VM Pod needs to come out of the shed
    this is not the right placement.
    That the CCTV connects to the VM Hub reveals the
    VM Pod is working so poorly the CCTV direct to Hub Wi-Fi
    is a better link.
    VM Pods must always be in a position where there is a decent
    signal from the VM Hub.  i.e. a lot closer to the VM Hub,
    perhaps in the house on the side facing the shed.
    • chrispy1's avatar
      chrispy1
      Up to speed
      If there was a decent signal I wouldn't need the pods.
      • jpeg1's avatar
        jpeg1
        As @Client62 has explained, the Pod must be in a place where it gets a good signal. It is a repeater - it only passes on some of the signsl that it receives.  In the shed it only receives the same weak signal as your devices are receiving, so they naturally ignore the Pod and connect directly to the Hub.
  • Hello chrispy1
    Sorry to hear of the wireless network signal and Pod in your shed, we appreciate you raising this via the forums.
    As Client62 has advised, there is no software for managing the pod's and we would also recommend relocating the pod from the shed to the property to ensure a stronger connection to the Hub therefore improving the signal strength and range.
