howardhj100's avatar
howardhj100
11 months ago
Connect app not finding my hub5
The connect app is not finding my hub 5 even though the iPad I am using to connect to it and do a hotspot check is right next to it. Please can someone advice.
regards Helen
  • The Connect app does not connect directly to the VM Hubs.
    It works via VM back office platform and there are a few things that can disrupt its operation :-
    1) VPNs especially Apple Relay.
    2) New installs / Recent Hub changes, it can take several days to a week to resume working.
    For now manage the Hub 5 at : http://192.168.0.1/  use the Hub Password (i.e. not the Wi-Fi Password).
    If you are unable to reach http://192.168.0.1/  disable VPNs / Apple Relay.
    • Gareth_L's avatar
      Gareth_L
      Hello iurdacosta27.
      Thanks for your post. Sorry to hear you are unable to use our Connect App.
      Can we please ask if you're using any 3rd party routers or a VPN at all?
      Have you tried reinstalling the App?
      Gareth_L
    I'd avoid the Wi-Fi Max / VM Pods.
    Invest in a Wi-Fi / home network / Mesh that you can own and more important can configure and manage.
    Consider where you need to have Wi-Fi coverage and how may network sockets are needed.
    We have two levels and a dozen rooms, to cover this we have a VM Hub in Router mode + a pair of Wireless Access points.   We also have network sockets in 4 rooms for VOIP, computers, printers, Sky Q etc.
    If there is a change of Hub it take me minutes to set the Hub to the desired SSID / Password and the Wireless Access points don't need to be touched.
    With VM Pods a change of Hub will result in days to weeks on the phone trying to get VM to accept the pods are not working and to find a person that will raise a finger to solve the problem.
  • Thank you and I did manage to do that but every device came up as move closer to the hub so I am non the wiser about my signals in different rooms. I wanted to check the signal in my upstairs office as I will shortly be working from home. Please advice how I can do this and do I need Wi-Fi max ?
    regards
    Helen
    • Daniel_Et's avatar
      Daniel_Et
      Hi howardhj100, thank you for your posts.
      We're sorry to hear about the problem you're having 😔
      Can you please check the Connect app has location permissions enabled?
      You can do this by going through the following steps: Settings > Privacy > Location Services > Virgin Media Connect > Change to "While Using the App"
      If they're enabled, please reboot the Hub, close down and re-open the Connect app and try again.
      Regards,
      Daniel
      • howardhj100's avatar
        howardhj100
        Thank you for your reply, I have done that and the app is still not finding my app, any further suggestions ?
        regards Helen
