- legacy1Alessandro Volta
Lucky you have to use the hub but it has modem mode because its not a hub5x
- AdduxiVery Insightful Person
VM do not use PPPoE, they use DHCP. Providing you do NOT have a Hub 5X, just set the Hub to modem mode and then connect it to your Router. It should issue the Router with a WAN IP and that's it. Note only one port on the Hub can be connected when it's in modem mode and that's the cable to the Router.
- jpeg1Alessandro Volta
You cannot avoid using the VM Hub.
- nodrogdVery Insightful Person
If your service is connecting to the hub via a fibre to coax ONT, then the internet service is DOCSIS based RFoG.
- Roger_GoonerAlessandro Volta
The hub incorporates the cable modem which is necessary. As advised put the hub into modem mode which causes the broadband to be bridged to the connected router. If the Ubiquiti UDM-PRO has dynamic DHCP enabled by default then it will work out of the box (might require a reboot after the hub has been put into modem mode).
Related Content
- 1 year ago
- 1 year ago
- 6 months ago
- 3 years ago
