ajh79's avatar
ajh79
6 months ago
Are power levels on upstream low?
I have a Virgin Hub 3 and I have experienced a couple of disconnections over the weekend. I believe I have a FTTC and then Coaxial from the cabinet to my property. I had a similar problem back in June where a moderator of this forum kindly arranged an engineer to visit and they stabilised my connection. The engineer replaced some component in my terminal box but did comment there was other components which appeared old and may need replacing in the future.
Anyway, I just wanted to post my stats and have a sense check from someone more knowledgeable than myself to tell me if my hub stats are an early indication of any problems.
Here are my upstream figures (the Power signals were consistently about 42dBmV a month ago. The figures below are consistent and have been like this over the last 48 hours although sometimes channel 3 modulation says "32 qam" rather than the 64 it says now):
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
13010000030512064 qam12
22360000028.5512064 qam13
33660000030512064 qam11
44310000030512064 qam10
54959999631.5512064 qam9
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
5ATDMA0000
Here are my downstream figures, although I think these are fine:
13310000002.238256 qam25
21390000006.438256 qam1
31470000005.838256 qam2
41550000005.640256 qam3
51630000005.438256 qam4
61710000005.338256 qam5
71790000005.138256 qam6
8187000000538256 qam7
91950000004.940256 qam8
102030000004.538256 qam9
112110000004.538256 qam10
122190000004.340256 qam11
132270000003.738256 qam12
142350000003.738256 qam13
153070000001.938256 qam22
163150000002.438256 qam23
173230000002.538256 qam24
183390000001.538256 qam26
193470000000.738256 qam27
203550000000.738256 qam28
213630000001.238256 qam29
223710000001.238256 qam30
233790000001.238256 qam31
243870000000.538256 qam32
1Locked38.9100
2Locked38.920
3Locked38.9110
4Locked40.390
5Locked38.9110
6Locked38.980
7Locked38.690
8Locked38.650
9Locked40.960
10Locked38.6140
11Locked38.980
12Locked40.390
13Locked38.980
14Locked38.970
15Locked38.640
16Locked38.9120
17Locked38.6110
18Locked38.980
19Locked38.660
20Locked38.960
21Locked38.980
22Locked38.670
23Locked38.9190
24Locked38.670
TL;DR = Do my upstream power signals look dangrously low and are they degraded enough to warrant an engineer to come out?
    The VM Hub varies its Upstream transmission power level to meet the demands of the Street Cabinet.
    What changed recently to enable the lower Upstream signal level to be received satisfactorily by the Street Cabinet ?
    E.g. has an attenuator been removed from the coax, or some of the coax replaced, etc ...
    • ajh79's avatar
      ajh79
      Back in June I think the cable from the back of the hub to the white box on the wall was replaced, possibly something in the terminal box itself (where the coaxial enters my property). However nothing has been changed in the last 4 months around the set up within my home.
      I didn't know the hub was able to adapt to the conditions of the street cabinet, good to know.
  • Tudor's avatar
    Upstream are below the specs I have unless you are on a RFoG connection. That said you have no T3 or T4 errors on the upstream, so that’s good. Downstream errors are fine, you must expect some. What missing is that you have not posted any 3.1 stats for either upstream or downstream. Are you very near the street cabinet? If so perhaps you need moving to another tap. Finally, apart from some drop outs, do you have any other problems?
    • ajh79's avatar
      ajh79
      No other problems apart dropout. Speed/latency seem fine. I'm probably about 300-400 metres from the cabinet.
      I don't have any 3.1 stats available in my hub, I only have a docsis 3.0 connection. Can you clarify where I should expect to find these stats please?
      • Alex_RM's avatar
        Alex_RM
        Hi ajh79,
        How have things been since you posted? I've ran through a few checks from our side, and there are no issues showing.
        Are you able to perform a pin-hole reset, and report back on if there's any improvement?
        Alex_Rm
    24 Downstream channels is the tell for a DOCSIS 3.0 connection with a Hub 3.
