SpacePhoenix's avatar
SpacePhoenix
Fibre optic
10 months ago
Are Hub 3s being retired?
I saw a news article today about older broadband hubs being replaced. Mine is a Hub 3 and when I went onto the page mentioned in the article to check if mine is included it says that my hub needs replacing.
Is the replacement of a hub a self-install or does an engineer have to do it?
If the hub 3s are being retired, which generation are they being replaced with?
I believe that my parents also have a Hub 3 so the same will apply to them as well.
  • The hub 3 is good for M600. I don't think VM is under pressure to replace it, and when it does it will likely be the hub 5X due to the migration to XGS-PON.
