sixfoottwo's avatar
sixfoottwo
3 days ago
Add Network to Hub 5
I have a hub 5 which was sent new with 2 networks - the one from the previous hub and a new one.
After an engineer visit 2 days ago, I only have the new network and not the original. Can I re-add the missing network with password back to my hub?
If so, how do I do it?
Thanks for any help.
  • Hi sixfoottwo,
    Thanks for posting, have you been able to connect your devices to the new hub or do you still need help?
    Alex_Rm
    Usually we get reports of the Connect app changing new Hubs SSID back to the old removed Hub.
    Using the admin menu of the Hub 5 it is easy to set the Wi-Fi SSID / Password to whatever you prefer.
    To keep it simple we use just one Wi-Fi network.
  • sixfoottwo's avatar
    sixfoottwo
    Updating one of my devices is particularly difficult.  Can anyone tell me if the above can be done easily?
  • legacy1's avatar
    Just reconnect all your devices by wifi to the new network
