fastboy's avatar
fastboy
18 days ago
1gb speed download .4mb,upload good.
noticed the other day my download speed had dropped to nothing and i couldnt even open  a webpage,today its done the same,restarting the hub 4 solves it for a while then does it again,i cant hear the fan spinning in the hub and wonder if its overheating?
how do i check?
it does feel hot at the top but not sure whats acceptable
  • fastboy's avatar
    fastboy
    hopefully fixed,they had to lay all new cable,100metres of it from cabinet to house since it had been in since 1999.
  • Hi fastboy
    Thanks for coming back to via private message to confirm your information. 🤩
    I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here 👉 My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
    Just to confirm, there will be no charge for this visit unless:
    • ➡ The technician diagnoses the faults as not being caused by our network/equipment
    • ➡ The technician discovers that the fault or problem relates to your equipment
    • ➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
    • ➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
    Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
    We will continue to monitor your services and if we can see that the fault has cleared and the visit is no longer required we will cancel the appointment and let you know by text and email.
    Let us know how the appointment goes. 😊
    Take care.
  • Minimum Guaranteed Download Speed:
    The guarantee applies to new customers that buy new broadband services, or existing customers that change their broadband service or re contract their existing broadband service on or after 28th February 2019. The guaranteed download speed is 50% of the advertised speed of our service on the date that you placed the order and is set out in the speeds table we send you. You need to keep your Virgin Media Hub plugged in, switched on and set to enable us to obtain speed information from it, which will help us to diagnose any problems. The minimum download speed guarantee does not apply to outages. If you experience an outage which affects your broadband services please contact us.
    What does the Minimum Guaranteed Download Speed mean?
    If the actual download speed provided from our network to your Virgin Media Hub falls below the Minimum Guaranteed Download Speed, and this happens for 3 consecutive days or more (whether continuously or intermittently during each day), and we are unable to fix the problem within 30 days of you reporting the problem to us, [[you may have the right to end your agreement without paying an Early Disconnection Fee. ]] You need to contact us if you have a speed problem via the contact us page
  • Hi fastboy,
    We're sorry to hear that you have been having an issue with your internet connection speeds. Checking things here, there are no faults in the area affecting you however it does look like your downstream power levels are out. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
    I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. Just click on the little ✉ at the top right-hand side of the page to access your inbox. 😊
