manncubdad
1 year agoOn our wavelength
Volume is too high when low volume levels selected
Recently been upgraded from V6 to 360.
Generally happy with it.
One issue is that since moving to 360, when low volume levels are selected using the 360 (or linked TV) remote, the volume levels are quite high.
For evening viewing level 4 is ok, but if I go it 5 its quite a volume jump and is too high for a quiet room.
Level 6 is just too high.
With my old V6 setup I would use levels up to about 12, and volume increase between each level was quite small. So I was able to fine yune my listening level. Deffo cant do that with the 360.
Is there anything that can be done to get that fine tuning of volume on the 360 ?
