Gavlar6's avatar
Gavlar6
Shrill sound when using microphone function and deleting recordings .
The shrill sound is emitted,usually, in the evening after a few hours use. I normally, watch breakfast tv until about 9..00 am , about 90 mins use, and then switched off until 12 noon. After continuous use until 5.00pm the fault starts to occur. The box does not feel hot. After 5.00pm every time I change channels using voice control a shrill sound is emitted, in addition this occurs when I delete a recording, manually,
I and not sure if the sound emits directly from the 360 or sondbar. Has anyone else noticed this?
  • Is this a high pitch noise that occurs just as you change to some channels?
    • Gavlar6's avatar
      Gavlar6
      Hi, the sound occurs on all channels and also when using the rewind and forward buttons. It has now started to emit the sound all the time when using any function on the remote. To try to remedy the problem, I have switched off the 360, allowing it to cool, but with no change.
