FromFrank's avatar
FromFrank
4 months ago
Number of problems with my V6 box
Hello all!
Just wondering if there is any way I could fix the following problems?
When on delay I get to a point in the program and it just stops and forces you back to live TV.
The streaming apps don't load a lot of the time.
Icons don't load on the menu either, just a bunch of blank boxes. This is both app logos and channel logos.
My streaming apps keep getting signed out which is annoying everytime I want to watch something
Sometimes I get code cs2400.
I have my router (also Virgin) quite close to the TV (due to location of plugs/connection box). The V6 is connected via ethernet so it shouldn't be an internet problem.
On another note, when I first received my router the on light is orange rather than white. I looked it up and it says it's because it may be refurbished and reused item. My internet both wireless and ethernet work fine as far as I know.
I tried connecting the V6 by WiFi instead of ethernet but nothing improved.
I also tried turning everything off by the mains and left the plug out for the right amount of time. The box seemed to work for a bit but then went back to how it was.
I don't know whether I've just got a dodgy V6 box that needs replacing or if there is anythingI could do?
  • Thank you all for your replies, and thank you newapollo for putting me in the right forum, appreciate it! So I have done a factory reset, changed ethernet port and I'm still getting the same problems including tv on delay stopping and forcing me back to live TV!
    • Steven_L's avatar
      Steven_L
      Thanks for coming back to us, FromFrank.  I'd be happy to take a further look into this for you; however, I would need to confirm a few details via private message. Please look out for my message, and we can get started.
      Kind Regards,
      Steven_L
  • Roger_Gooner's avatar
    Roger_Gooner
    This problem has nothing to do with BBC, faulty LAN connection or failing hard drive, rather it's because the hub is faulty or its firmware is corrupted and causing the 360 to suffer cascading failures because it cannot maintain a stable IP session. This leads to all the faults described. In more plain English you could say there is a dirty connection between the hub and the CMTS at the headend.
    VM must replace the hub and preferably with a hub 4 or a hub 5.
  • Hi FromFrank,
    Thank you for informing us of this and we're sorry to hear about your V6 issues.
    Can we ask if you have followed the steps provided by newapollo and whether these have fixed it or not?
    Please inform us if so and if not, we'd like to investigate this further with you.
    • FromFrank's avatar
      FromFrank
      As stated below, I have done a factory reset, changed ethernet port and checked the Internet (which seems fine). I'm still getting the same problems including tv on delay stopping and forcing me back to live TV.
    I've moved your post to the 360 forum.  The error code you mentioned (CS2400) doesn't apply to V6 or tivo boxes, but only to 360 and Stream boxes.
    Error CS2400 mainly affects BBC channels - there is a workaround. You can force the BBC  channel to play without the pop up reappearing if you hit the back button on the 360 remote when the error message appears, and then press pause and play. Basically it ties in with a loss of internet connection and the BBC channels trying to connect to the red button even if you haven't pressed it.  It can also signify the beggings of a hard drive error.
    It sounds like you migrated from a V6 to 360 TV system.   That migration process deletes the tivo operating system from the box when the hard drive is formatted and replaces it with Liberty Global's (VM's owners) in house Horizon Entertainement system.
    So the box is now termed a 360 box s it has no remnants remaining from the tivo/V6 system.
    The errors you describe (channel and app icons not showing, apps not loading) are a result of a loss of internet connection. Since you are connected by ethernet cable this shouldn't be a problem.
    It's possible that your ethernet cable is faulty, or that the ethernet port on the 360 box or VM hub is faulty. Which VM hub do you have? Have you tried a different ethernet cable?  Or a different ethernet port on your hub?
    When you tried setting up a wifi connection to the 360 box then providing you removed the ethernet cable form the 360 box and entered the Wifi SSID and password it should have worked.
    The streaming apps being signed out can be due to loss of internet connection, but can also be caused by turning off the 360 box at either the wall plug, or the rocker switch on the back of the 360 box.  This can also be the sign of a hard drive issue , which might also be linked to the orange light showing as that can be another indcator of a possible due to hard drive issue.
    Does your 360 box lose recordings?
    What happens if you pause a live TV program for a few of minutes and then play it back  again?
    Have you tried a factory reset?
    To factory reset go to Settings (the cog at the end of the Home menu) > System > Factory Reset. It's actually misnamed and only a partial system reset and not a complete factory reset. You are given 2 options
    Keep Recordings
    Format Disk
    Select Keep Recordings, which means you won't lose your recordings, and any planned recordings, or series links you've set up. You may have to sign into your apps such as iPlayer, Prime, Netflix and ITVX again.
