Wow has this issue really been going on for almost a year!??
Amazing.
Since there is absolutely no explanation from VM regarding this issue, my personal idea is that this happens because VM commission a bulk load of devices from the cheapest possible designers and aim to be locked with the devices for 10 years minimum. When I say the "cheapest" designers I really do mean the cheapest ones with absolutely no experience whatsoever.
For example; the HUB3 has been designed by someone who has no idea about ICMP filtering, Based on the fact that such a basic industry standard thing is missing from a router, you can assume that the firmware has been designed by someone who has never designed a router firmware in their life!.... (you should see the VM router firmware, it's like a school IT coding project)
... If you apply the same logic to the TV software, it all makes sense. It's been designed by the cheapest possible designer who has never designed a TV box software before, they tried hard to copy TiVo, but simple things like audio sync, which work correctly on every other TV box on the planet, are not implemented properly based on industry standards.They are also bound to keep the devices for 10 years.
This issue should really take 2-3 days to solve for any competent CEO, 3 days tops from initial report to fix deployment. I honestly cannot believe this has been completely ignored for almost a year. I bet the CEO has no clue about cable TV unfortunately. And this is the case with all modern CEOs.
When Ford started selling cars he knew about building great cars, When Bill Gates started selling software, he had a passion for software. Nowadays anyone in charge of a company has absolutely no idea about the product it sells, they only know the price to sell it at, nothing else. Liberty global is a disease of European Cable TV, with a tactic of locking people into cheap internally commissioned hardware.
At the end of the day, Cable TV should be receivable by any DVB-C tuner with nagravision encryption. I don't understand why VM insist on forcing viewers to use horrendously cheap £5 TV boxes, when customers should be able to go out and buy their own professionally designed cable set top box and push a smart card into the back of it.
