SajH's avatar
SajH
4 years ago
360 Box ARC problem
Anybody know of issues with 360 box not supporting ARC? I’ve a Samsung QLED and a Samsung Soundbar, my issue is my 360 box disconnects the ARC off my sound bar, I’ve done everything correctly, I’m clued up on my stuff but this has really annoyed me, I’ve tried everything I’ve swapped my one connect box to see if that’s the problem, I’ve swapped my soundbar to see if that’s the problem, changed cables, hard reset both tv and bar. Sound comes on ARC on bar for a bit then goes back to tv speakers. Sometimes if I disconnect all cables , unplug everything then switch back on after 20 minutes it works, then if I switch it off and back on it reverts back to tv speakers. I’m hoping someone has a solution or someone from Virgin Media can shed some light on this issue, as for me it’s a big issue and very frustrating!!!!
  • I had a similar issue. I found setting the following to my sound device (rather than TV) made it work:
    360 Home > Settings > Audio & Video > Volume keys control  - press ok on this to switch from your TV to your sound bar
    • SajH's avatar
      SajH
      So did this fix the issue with ARC ??, so you are saying if I follow what you done then ARC should work all the time without an issue?
      • mcinp's avatar
        mcinp
        Yes, that worked for me and I was hoping it would work for you to.
    • SajH's avatar
      SajH
      So I’ve tried what you recommended , unfortunately worked for a short while. So to test it I put the 360 box in standby and then start it up again and Surprise surprise it defaults back to D.IN Not ARC and TV speakers kick in. 🤦🏼‍♂️
      I am so frustrated and annoyed with this 360 box
      • Kath_P's avatar
        Kath_P
        Hi SajH,
        Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
        I'm afraid there isn't much advice we can offer you on this since we're not able to support third party equipment.
        The community may have some advice to offer though as many of the users have good technical knowledge of the sound bars and the best settings to connect them on.
        Failing that, you can sign up to our Gadget Rescue service who also may be able to help.
        Let us know if you have any further issues.
    How is the 360 connected? Is it direct to the TV or soundbar? The 360 doesn't use ARC so why do you think it is the problem?
    • legless051202's avatar
      legless051202
      I have a one connect box for my Samsung QLED, I have the 360 box going into that going in HDMI 1, HDMI 2 is ARC  on the one connect box so I have HDMI from that to ARC on Samsung Q70T Sound bar. In HDMI 3 I have my 4K blu ray player going in. If I only connect the blu ray than ARC works fine, soon as I connect the 360 box it may work for a short wile then it goes bk to D.IN and not ARC. I am clued up on the equipment as I have worked in electric retail for a long time and I know my stuff. I’ve even purchased the high speed cables. I can only put it down to the 360 box.
      • NinjaMeerkat's avatar
        NinjaMeerkat
        Fibre optic
        What testing have you done? Have you tried just the 360 connected without the player? Have you swapped cables and connect box hdmi ports? Does your TV and soundbar have eARC? Are you using CEC?
    • Mike1957's avatar
      Mike1957
      @kilmaster
      Sounds like the issue I am having. I had no problems with my Tivo box, all connections are the same, VM just changed the Tivo box to a 360 box and the audio issue started.
      I'm thinking of trying the CEC less from Amazon but before buying want to make sure connections are the same.
      I have TV connected to sound bar from TV's HDMI ARC to sound bar's HDMI ARC.
      Then I have TV's HDMI connected to V360's HDMI.
      Is this your connection setup too?
  • Hi, been with VM for a month. Samsung TV and Q700B soundbar. All worked well with Sky. Can't get Arc to work now. New cables, reset everything and nothing.
    • Adri_G's avatar
      Adri_G
      Hi, NeilB1878.
      Thanks for taking the time to post on the help forums and this thread, although we're sorry to hear you're facing problems with your TV and soundbar not working well with our services.
      Can you please share what model exactly is your TV and soundbar apart from the make so we investigate further?
      Cheers,
