Lee4498's avatar
Lee4498
Wifi volt pods
My volt benefits were applied today and after a speedboost i am still only achieving 19mbps in my bedroom (i have tested via virgin media connect app).
could i please order a wifi booster pod?
many thanks
Lee Duke
1 Reply
  • jbrennand's avatar
    See thus...
    VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
    You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
