HeyJoe_again's avatar
HeyJoe_again
8 months ago
Upload speed problem
My internet speed has been up and down a lot over the past few days. Meant to be getting 350mbps download but lowest I've recorded is 30mbps - slightly annoying but fine to wait out.
The big problem is the upload speed, which I think is advertised as 35mbps is coming in at less than 1mbps, sometimes as low as 0.17mbps. I can't even upload a file with this. Really impacting my internet use.
Anybody know the best way to go about fixing? The issue has only really been noticeable over the last few days.
1 Reply
  • jbrennand's avatar
    Have you checked first for any “known network faults in your location - Look in 2 places
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
    If nothing is reported on there, can you do this.....
    __________________________
    First Switch the Hub off for 5 minutes AND unplug it from the mains. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc.  Disconnect all the connections and reconnect to be sure.    Ensure there are no “unterminated cable loose ends or loose wires on the connectors . Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling (no clips piercing iit, or broken sheathing) and the wall box. Then switch it on again and see how it is.
    If its no better - do this.....
    Post up your Hub/network connection details in the format below and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1  if in router mode or 192.168.100.1 if in modem mode.     No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
         Then… Navigate to these “data pages” and just copy/paste the normal  “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables in the Downstream tab, the 2 in the Upstream tab, &  the Network Logs pages.  Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    Also, If you haven’t already, set up a free, secure and “offlsite”  - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts.  It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”.  Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see.  On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
