Signal errors? Need an engineer?
For the past month or so I am getting regular drop outs and stuttering. Streaming TV on my Firestick I get regular freezing and stuttering, last night on the Paramount+ app it was constant. Also online gaming is being affected with connection errors. I also stream a weekly podcast with my friends and the past 3 weeks I am getting tons of dropped frames.
A speed test shows everything OK and theres no issues in my area according to the VM status checker.
Looking at the logs theres a lot of errors, a quick google and its showing there is probably a signal error to the hub (Hub 5 in modem mode).
Below are the logs. Do I need an engineer out to check levels etc? Its so frustraing having this issue, just seems one thing after another lately as had some local issues recently too which has affected service. Been with Virgin since the Telewest days but am seriously considering leaving when my contract ends early next year :(
Mark.
Time | Priority | Description |
07-09-2025 10:48:23 | notice | GUI Login Status - Login Success from LAN interface |
07-09-2025 03:29:41 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 03:29:41 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 02:27:46 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 02:27:46 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:28:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:28:42 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:18:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:18:21 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:39 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
07-09-2025 00:17:33 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:33 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:33 | warning | Dynamic Range Window violation |
07-09-2025 00:17:33 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:28 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:24 | notice | TLV-11 - unrecognized OID;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:22 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:20 | notice | Honoring MDD; IP provisioning mode = IPv4 |
07-09-2025 00:17:09 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
07-09-2025 00:17:08 | critical | Cable Modem Reboot because of - Reboot UI |
30-08-2025 23:28:13 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
30-08-2025 23:16:40 | critical | Cable Modem Reboot because of - Reboot UI |
30-08-2025 23:16:40 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
14-08-2025 11:17:17 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
14-08-2025 11:17:17 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
14-08-2025 11:17:17 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
14-08-2025 11:16:57 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
14-08-2025 11:16:57 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:a5:24:8a;CMTS-MAC=b0:8b:d0:6d:a9:61;CM-QOS=1.1;CM-VER=3.1; |
