- Client62Alessandro Volta
Realspeed works fine for VM Hubs in Router mode.
With VPNs disabled and Apple Relay disabled try at :
https://real-speed-fe.eu1.sk.thousandeyes.com/
The same VM Hub “Realspeed” tests are available as very handy & free
apps for iPhone/iPad and Android mobile / tablets.
Post screen shots of the errors if this does not work. - bk_vmediaJoining in
I tried, not working. No vpns. Tried with urls and Android app also.
Error is there was a problem running the router test. Try again a bit later.
Any further suggestions?
- Cardiffman282Community elder
Yup. Contact customer service https://www.virginmedia.ie/contact/
Did the Realspeed links I gave ever work against your VM Hub 5x ( they work in the UK ),
or did they work against some kind of Realspeed box that was attached to the Hub ? - Roger_GoonerAlessandro Volta
Realspeed works for me using PC and Samsung phone. What hub and browser are you using and provide, as suggested, a photo of error message.
Also try a reboot of the hub.
- AdduxiVery Insightful Person
Maybe it’s not working for VM IE ?
Related Content
- 8 months ago
- 1 year ago
- 2 years ago
- 1 year ago
- 11 months ago
