bigguy283's avatar
bigguy283
Up to speed
PLEASE help, how do i get a wifi pod? i'm on new 1gb but bad wifi upstairr
as above,  i have tried to get a wifi pod, as my conections upstairs keep dropping, i looked at all the help pages, and it says you can order a FREE pod , if you click on my virgin media, my package, and in there will be a wifi max , link, to order your first pod!   . THERE IS NO LINK . here is what my package says for broadband:-
Volt Gig1 Broadband
You’re signed up to Volt benefits!
Exclusive benefits you get when your household is with both Virgin Media and O2.
My Volt benefits
• A broadband speed boost to the next available level (if you aren’t already on the fastest speeds you can get in your area)
• Up to three WiFi Pods at no extra cost if you find any pesky WiFi blackspots in your home
  • jpeg1's avatar
    jpeg1
    You must first demonstrate the need for the Pod, by using the VM WiFi app.
    • bigguy283's avatar
      bigguy283
      Up to speed
      i have used the VM connect app, now what? as i said the connection is up and down like a fiddlers arms!!
      i need a pod on my landing upstairs to get constant connection in upstairs bedrooms
  • jpeg1's avatar
    jpeg1
    Well I don't use the pods, but the app was supposed to allow you to order one.
    If that isn't working, wait for a VM person to pick this up and offer to help.
  • thanks for replying,  i will wait for help on here, it is so annoying, virgin media website is terrible  and so out of date, it even talks about using wifi connect app to find wifi hotspots while out and aboutm but of course they stopped all the wifi hotspots months ago !!!
    • Sabrina_B's avatar
      Sabrina_B
      Hi bigguy283 👋
      Thanks for reaching out to us. Apologies for the issues that you are having with ordering a pod, we would need to bring you in for a private message to discuss this and resolve.
      Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
      Thanks.
      Sabrina
  • jpeg1's avatar
    jpeg1
    Yes it is terrible, but at least it's consistent with the rest of VM's customer service.
  • many thanks @Sabrina_B  you are a very helpull person 👍
