conman33158's avatar
conman33158
Super solver
Is it a case of over utilization?
It's been a while guys......This is my daughters line, voltages a bit low in places but just need a second opinion before recommending she switch ISP's 🙂
I have the Hub 3 in modem mode with TP Link Decos, it's even worse with connection issues in router mode.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/61c4e0f30cec9fee1dbbd3ceebb5c3ab2d0f0f68
https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/61c4e0f30cec9fee1dbbd3ceebb5c3ab2d0f0f68.png
Item
Status
Comments
363000000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
363000000
3
40
256 qam
29
2
139000000
4.1
38
256 qam
1
3
147000000
3.7
40
256 qam
2
4
155000000
3.9
40
256 qam
3
5
163000000
3.9
40
256 qam
4
6
171000000
4
40
256 qam
5
7
179000000
4
38
256 qam
6
8
187000000
4
38
256 qam
7
9
195000000
4
40
256 qam
8
10
203000000
3.9
40
256 qam
9
11
211000000
3.7
40
256 qam
10
12
219000000
3.9
40
256 qam
11
13
227000000
3.7
40
256 qam
12
14
235000000
3.5
40
256 qam
13
15
307000000
3
40
256 qam
22
16
315000000
3
40
256 qam
23
17
323000000
3.2
40
256 qam
24
18
331000000
3
40
256 qam
25
19
339000000
3
40
256 qam
26
20
347000000
3
40
256 qam
27
21
355000000
2.9
38
256 qam
28
22
371000000
3
40
256 qam
30
23
379000000
3
38
256 qam
31
24
387000000
3
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
49322
170058
2
Locked
38.6
42505
236113
3
Locked
40.3
43144
227661
4
Locked
40.3
42527
228938
5
Locked
40.9
42194
235522
6
Locked
40.3
44263
228840
7
Locked
38.9
44235
229094
8
Locked
38.9
46014
218768
9
Locked
40.3
44739
227291
10
Locked
40.3
46040
218643
11
Locked
40.3
47237
210995
12
Locked
40.9
46460
213646
13
Locked
40.3
47669
208420
14
Locked
40.9
46330
210692
15
Locked
40.3
49964
190241
16
Locked
40.3
49624
192081
17
Locked
40.3
50277
186945
18
Locked
40.3
50960
179535
19
Locked
40.3
52028
173340
20
Locked
40.9
50092
176653
21
Locked
38.9
49986
174408
22
Locked
40.3
49194
166871
23
Locked
38.9
48083
162880
24
Locked
40.3
48380
161516
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
32.8
5120
64 qam
13
2
23600000
33.3
5120
64 qam
14
3
39400007
34.8
5120
64 qam
12
4
46200000
32.8
5120
64 qam
11
5
53699949
33.8
5120
64 qam
10
6
60300002
34.3
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
6
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
2
0
6
ATDMA
0
0
0
0
  • I'd say those errors are a result of the appalling connection, rather than the cause.
    Have you checked the local faults line? Reported it as a fault?  There's no way she should suffer this if there is an option available.
    I'd focus on the Post RS Errors on all 24 channels resulting from a downstream noise issue
    as being a likely problem for connection reliability :
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    40.3
    49322
    170058
    2
    Locked
    38.6
    42505
    236113
    3
    Locked
    40.3
    43144
    227661
    4
    Locked
    40.3
    42527
    228938
    5
    Locked
    40.9
    42194
    235522
    6
    Locked
    40.3
    44263
    228840
    7
    Locked
    38.9
    44235
    229094
    8
    Locked
    38.9
    46014
    218768
    9
    Locked
    40.3
    44739
    227291
    10
    Locked
    40.3
    46040
    218643
    • conman33158's avatar
      conman33158
      Super solver
      These would be here from the hub was first powered on about 2 years ago, I must do a reset off the hub and see what pops up 🙂
  • jpeg1's avatar
    jpeg1
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      Ugh. Halloween really has come early for Caitlin looking at her BQM. In addition to checking for local faults have another look at all of the cables and connections (and maybe a quick scan of the external cabling too).
  • Thanks for the input guys, will reset everything tomorrow and check all connections which all seems to be fine plus I’ll get a call into the faults line and if no faults get one logged. Hopefully it will be a simple engineer visit to sort it out.
  • After being cut off 4 times on the phone we finally got an engineer visit for Friday 25th Oct between 1-4pm. Hopefully the guy sees the issue. Had to laugh at them trying to get Caitlin tied into another contract when the issue is unresolved, nice try matey...lol
    • Carley_S's avatar
      Carley_S
      Hi conman33158
      Welcome back to the community forums
      Sorry to hear of the concerns you have with your services at this time.
      Please do keep us posted on how your engineer visit goes tomorrow, we'll assist further should you need.
  • Well the engineer came early so better than we thought as he had a cancelation. He just done a new install of equipment, cables and power supply etc as he could rule out which was casing the issue. Installed new cables, and new Hub 5 and new power supplies where needed. Vast improvement on the BQM now so hopefully no more bother.
    Cheers for all the help guys, much appreciated! 🙂
    Broadband Quality Monitor | thinkbroadband
      Cardiffman282
      Community elder
      That is a much better VM BQM. You are showing off with your EE FTTP BQM though 😊
        conman33158
        Super solver
        The EE/BT is a hard one to beat my friend 😂
