Jessi1's avatar
Jessi1
10 months ago
Intermittent Signal
I pay for 500mbps download speed and 50mbps upload.
I use an ethernet cable from the modem/router to my pc.
I've been having issue with the upload speeds not being what they should be at RANDOM times throughout the day. But what is is going on here?
Originally, I thought the speed drops past 8pm randomly but no it was throughout whole afternoon one day. Every speed testing I've done has always been different.
I just tested again..
It's not 50mbps upload but it's not unsuable??? So why do I lag so much and have ridiculously high ping in games and calls. Ping spikes to 500-1000ms back down and up and it's stable throughout random times in the day. It's not just one game its all games. Testing on my phone and the uploads are the same download speed is less but I use my PC more.
This is a screenshot I took one night 15/05/2025
What I've tried:
I had an engineer come say he didn't see anything unusual because he didn't see any logs where my upload speed drops... Said he couldn't do anything, gave me his phone number said he would contact me back to see if it was on virgin media's side but hasn't contacted me since and its been 6 days and I even tried contacting him on the number he gave and no response.
Called virgin after and they suggested I do factory reset. It was 50mbps upload after the factory for a bit then it just went back down.. So that didn't do anything. They told me if that didn't work they would send me a new router.
Live chatted with someone told them everything and they just sent another engineer.. Told them about me realising that there are T3 Timeouts on Channel 5 (if that had anything to do with it) The 19 timeouts racked to 25 the day after this screenshot where the engineer had visited.
Engineer told me they cleaned the cables . Told me it's rare but it might be feedback coming back into the router from my ethernet cable.
Just checked again and my channel 5 T3 Timeouts is now 1 after they visited.
I was getting 50mbps for a bit after the engineer left its down again.. Internet sometimes feels slow when I'm just browsing and loading links.
I don't understand it all too well.. But all I know is that my ping is ridiculously high and low in games and when I have 50mbps upload that is never an issue and it is more stable. It's not just ping it's calls, streaming my screen to friends in call too. It NEVER used to be like this!! It's been happening for nearly a month. My upload speed can say 0 mbps but I can still upload a file. I see it going 0 to 3 to 4 to 9 . It's all over the place. I'm really lost.
I didn't end up recieving a new router but that is my last hope.
Another thing I was worried about if it was my computer itself, because nobody in my house uses the internet as much as I do and on mobiles it's not that noticeable unless you tried to play a game on mobile. Uploading files is slow but bearable. I've tested my ping on my computer with cmd, everything looks fine. My applications arent even using a lot of upload speed they don't even require that much.
I even purchased a new ethernet cable but that didn't change anything.
I also decided to test for bufferfloat. Thinking of buying a router now but im worried that will not solve my issues.
I'm really confused and need help.
    The results from the Realspeed test do look suspect especially where the speed figures at the Hub are less that those at the Device.
    Samknows Realspeed is also available as apps for Android and iPhones.
    See if these give same results.  Over Wi-Fi I focus most on checking the service speed at the VM Hub as expected, for the Wi-Fi devices the figures will vary.
    Check for known faults in your street – try both methods :
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    • Jessi1's avatar
      Jessi1
      Hi, I just called the faults and they say there is none in my area.
      When I check the virgin media service status check, it either tells me its intermittent signal in my area and they are looking into it and to come back in 24 hours. I come back in 24 hours and it says to book and engineer. I've done that twice already.
      This is a test on the app with my phone right next to the router/modem
      • David_Bn's avatar
        David_Bn
        Thanks for reaching out to us Jessi1 and a very warm welcome to our Community Forums!
        We're sorry to hear of the poor experience you have endured on our services recently.
        It looks like you may have since been able to speak to our team in relation to the issues at hand.
        Can you please confirm if you have since seen an improvement in our services?
        David_Bn
