wymondham1's avatar
wymondham1
10 months ago
Increase upload speed later....
Hi Everyone, I'm looking at getting the 512Mbps Virgin Broadband package. If i use links to enable cashback (£70) then i dont have the choice to add the £6 a month matched upload speed.... question is, if i order this way, can the upload add-on be added later once the system is running?  thanks!!!!
    Interesting, I thought symmetrical was only available on 1 and 2 Gb Tiers?
      Can you post a link to this information please?
      • Buffer6's avatar
        Buffer6
        You should find all the info here
        Virgin Media switches on residential 2Gbps broadband service | Virgin Media Community - 5479607
        Customers in full fibre areas will also be able to boost their connectivity with a major upload speed add-on, providing them with symmetrical speeds so they can upload as fast as they can download.
        This upgrade is available across all of Virgin Media’s speed tiers – from 50Mbps to 2Gbps – and marks Virgin Media becoming the first major UK broadband provider to offer this optional service.
        Gig2 is available for £84 per month with the option to add symmetrical speeds for an extra £6 per month across all speed tiers.
