Pendlebean's avatar
Pendlebean
Help! Got 1GB internet and hub 5 but download speed of 300mbps
Hi, as the title states we  are paying for 1 GB internet and getting nowhere near what we are paying for, I have tried 2ghz and 5ghz virgin website says no problem in the area, it’s driving me nuts as getting a lot of buffering and thinks like Netflix and YouTube. Please can some body help me . Have tried restarting the router also. We do not have many connected devices either, I have tried restarting the router also.
    Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
    Post the power levels, Pre and PostRS errors and network log from the Hub. Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping
    Once done we can comment.   However there is something amiss, as SamKnows is only reporting 274Mb to the Hub.
  • Tudor's avatar
    Don’t forget VM ‘guaranteed’ speeds are for Ethernet cable connected devices.
    • carl_pearce's avatar
      carl_pearce
      Superstar
      The speed to the HUB is only 274Mbps, so not related to Wi-Fi.
  • legacy1's avatar
    Your phone is slow or the hub wifi is the problem which you can fix by getting your own router with 1Gb ports and use hub in modem mode
  • Hey Pendlebean, thank you for reaching out and a warm welcome to the community I am so sorry to hear this.
    Can you confirm if this is on a WIFI or a cable connection or even both for us?
    The speeds you get at home will, of course, depend on a variety of factors, it depends on your package, what and how many devices you have, how they are connected amongst other things.
    We do have a download speed guarantee though - this will show the minimum speed we would expect for all our packages - you can take a look at that here:
    Please keep us updated.
    • Pendlebean's avatar
      Pendlebean
      Thank you all for your responses, the issue tuned out to be the person who did the installation had put a staple through the cable, all good now !
        Well, that's one sure way to disrupt a signal ....   😉  Glad it's all sorted and thanks for the update !
