RyanD27's avatar
RyanD27
Faster Upload speed
Hi all
My contract is coming up to finish shortly and I'm looking to get symmetrical speeds, How do I find out if this is available to me?
If its not available then ill need to move away from Virgin considering I could pay the same to another company and get the symmetrical speeds I desire.
Cheers
Ryan
  • Is your existing connection FTTP or HFC (Coax)?
    Symmetrical speeds wouldn't be available over coax.
    • RyanD27's avatar
      RyanD27
      How would i tell? I have 1130Mb download 100 Upload currently.
      • carl_pearce's avatar
        carl_pearce
        Superstar
        What HUB do you have?
        Does it have a coax or fibre connection?
  • If your on 1130 you are like on Co-ax, you need to be on the 2 Gig Fiber to the home to get the faster upload.
  • Roger_Gooner's avatar
    Roger_Gooner
    Unless you have a hub 5X you aren't on the network that provides symmetrical broadband, and there is no upgrade from legacy hubs either.
    • Matthew_ML's avatar
      Matthew_ML
      Hey Roger_Gooner, thank you for reaching out and are you having trouble with your speeds?
