old_grey_grumpy's avatar
old_grey_grumpy
bad wifi speed
Have hub 5
I am on a recently formatted macmini
using sam know the speed to router is 1145mbps but device speed show as low as zero fluctuating to almost 400 then down on refresh.
Had one engineer last Monday say problem on upstream as phone calls were dropping.
spoke to our friends in India to be told they only test download not upload/streams
after 2 hours on phone and 3 operators got to speak to a manager and arrange for another engineer any one know what problem could be
  • jbrennand's avatar
    Is that with the Mac connected to the Hub via a Cat6a ethernet cable - or wi fi ?
    If wifi... test it on a cable connection and see what that gets.  If that ethernet connection is poor then can you post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
    • old_grey_grumpy's avatar
      old_grey_grumpy
      John my wifes pc is ethernet it shows speed of  946 mbps but web pages still buffer
        OK - Post up the Hub stats as per above.
    946 Mb/s on the Memsahib's PC is as good as it gets on a 1Gb/s NIC.
