StevenJonSmith's avatar
StevenJonSmith
2 days ago
Hub 5 to 5x - Fibre Up
Hi, I've just had my Fibre Up upgrade but my existing WiFi Pod (black - WiFi 6) is not connecting to the new router. I did speak to customer support but they've chosen to ship a new pod. Please can someone check if the existing pod can be re-assigned to the new hub, as otherwise it's e-waste even though it seems like it should be functional (lights all cycle, was working right up to the router change). I've been told it can't be replaced until there are 3 pods on the account already, but I'm not going to hold onto it for future replacement if it doesn't work now.
  • No idea who split this thread out, it was posted as a reply to a WiFi Pod issues thread and that important details feels a bit lost given the title it was given in the split. If a moderator or staff member is splitting stuff, it would be good if they made comment regarding doing it.
  • Just to clarify have you gone from a coaxial connection to a Xgs-pon connection? If so how did VM let you know that this conversion was available to you? Also roughly where in the UK are you please?
