tagz23's avatar
tagz23
Cable needs to be cut and relocated
Thank you for this reply. Do you know how I contact VM to have a phone/broadband cable coming into my flat re routed? Currently it’s coming in through a hole drilled into the sash window frame. The window is going to be replaced and the cable needs to be cut and brought in through the wall. This must be done before the window people can do their work.
Many thanks in advance
    £25 non fault call out fee.  If you wait here a day or two a VM Mod should pick this up and discuss directly with you.  Note if this is above 1st floor it may need a special team trained to work at heights.
  • Hello @Akua_A
    Please contact me about relocating the cable coming into my flat.
    Many thanks
    • Tom_W1's avatar
      Tom_W1
      Hi tagz23 thanks for your post here in the Community, we can definitely try to help here.
      As mentioned, this is subject to the £25 callout fee but we can get this in place for you.
      Please expect a PM from me to arrive shortly and respond directly when you can!
      Many thanks
