- TudorVery Insightful Person
Is it a hub3?
- thefamilymeeTuning in
Yes it is. It seems to have factory reset it self and began flashing about 5 mins ago and now is constant red again.
- Paul_DNForum Team (Retired)
Hi thefamilymee,
Thank you for reaching out to us in our community and welcome, we are sorry to hear you have a constant red light on your Router and can only connect one device, I was able to locate you on our system with the detail we have for you and can see there are some short term connection issues, please can you check all your internal connections are hand tight, this includes all connections coming into the property, all equipment plus any splitters both standard and powered, once done try a pin reset, push a pin in the reset hole at the back of the Router and keep it pushed in for a full timed 1 minute, once done allow 15 minutes to settle.
Paul.
Hello. I tried all that. No change still solid red light.
The router is now not showing up on the available wifi list, either as its given name or its default name. Is it safe? Some forums are suggesting an overheat.
Thank you for trying everything, so I can help further and arrange a Technician if required, I will send an invite into a private chat, please click on the white envelope to accept.
Paul.
Related Content
- 7 months ago
- 2 years ago
