jayb73's avatar
jayb73
help - WiFi connection issues
have got 1 gig broadband but since upgrade have lost almost all wireless conections have been trying to get it sorted for a week so need engineer to call in to sort it as that is what im paying for please help urgently
[mod edit - title edited for clarity]
  • Hello jayb73,
    Welcome back to the Community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your connection at the moment. I've looked into your connection and can see that your downstream power levels are too low and this is what is causing the issues that you're experiencing. An engineer would need to attend your home to resolve the issues. I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment. Please look out for the private message and we can get started.
    Kind Regards,
    Steven_L
  • legacy1's avatar
    VM only support 30Mb over wifi if you want the full speed use wire because there is a wire to the hub for a reason or else the hub would only have power only
    • jayb73's avatar
      jayb73
      i am using wire to pc but need wireless for my printer and google home  is it unreasonable to expect that as it used to work on virgin 5oo speed
      • Steven_L's avatar
        Steven_L
        Hello jayb73,
        Kind Regards,
        Steven_L
  • legacy1's avatar
    I'm sure a printer uses less then 10Mb VM don't support google home
