Not getting 1GBPS on Gigabit internet
Hi All, I have extensively checked as to why I am not getting my full 1000 down and cant find a solution. I have a powerline adaptor which initially is only getting 200 down (it supports gigabit, and is ethernet run) so I have then ran a Cat 6 High quality *copper* ethernet cable directly from my router to my PC (2.5 gig port) and this is only returning speeds of ~400mbps. My phone on wifi has gotten 800 down max. My network card in my PC supports 1gbps and I have also used safe mode networking and booted into it to try and still only getting 400 down. Im not sure why this may be? Thanks1.6KViews0likes3CommentsInternet less than 30mbps. How to order a pod?
Hello, im a Virgin Broadband and O2 customer. I ran a speed test today, as I can barely use the internet in half of my flat. It came out that I have less than 30mbps speed. I will need a pod to enhance the signal but as per Virgin media tradition, there is no straightforward guide on how to achieve this. Could I get some help please?834Views0likes4Comments
