- newapolloVery Insightful Person
Hi memzzy
You need to perform the Home Scan using the Connect app in the area where the signal is low(est) or as near to there as possible. The home scan feature will guide you from room to room to carry out WiFi speed tests. If it finds a potential signal-less spot, it’ll test your broadband speed to the WiFi Hub to make sure there isn’t a problem with your network.
If everything’s okay with the Hub, the app will take you through to order a WiFi Pod to help boost your WiFi connection.
How to perform the scan and order the wifi pods when using the Connect app.
- Tap Start the scan and then
- While connected to WiFi, Tap "I’m ready " and then wait a couple of minutes for the scan to complete, and then tap Continue
- Tap Add a room, and at on the room you're in, then Start the Scan (do this in every room)
- When the scan is complete tap Optimise WiFi now if the options shows as that will try and improve the connection in the current room
- When it shows Optimisation complete, tap Rescan room, tap Start Scan and then you can click on Order a WiFi Booster if it shows as an option
If that doesn't work you can call 0800 064 3850 to order the first one
VM will only send out one at a time, and there must be at least 7 days before ordering each one. It's up to three in total depending upon coverage.
Following that if you need additional pods you can order them by logging into /my-virgin-media, as per the info below from https://www.virginmedia.com/wifi-max ?
How do I get a second or third WiFi Pod?If you’re not getting download speeds of at least 30Mbps in every room with one WiFi Pod, you can request a second or third by signing in to My Virgin Media, clicking on Your Package and following the steps in the WiFi Max tab - Steven_L
Hey memzzy,
Welcome to the community and thanks for taking the time to post here on the forums.
Have you been able to get a pod order with the advice from newapollo or would you need further assistance to get a pod ordered?
Kind Regards,
Steven_L
Related Content
- 2 years ago
- 10 months ago
- 2 years ago
- 2 years ago
- 12 months ago
