Steven281180
12 months agoJoining in
Order WiFi pods
hello am only getting 5mps upstairs in my house using the connect app . Its tells my to order a WiFi pod but gives you no options to order one . I’m going round in circles
Hi Steven281180,
We're sorry to hear you're having an issue with your connection and require a WiFi pod to help improve things. This is something we can certainly check for you but in order to do that I will need to confirm some information with you to pass security.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
