AmandaCD's avatar
AmandaCD
How to order a wifi pod
Can somebody tell me how to order a pod? The website said use the app, scan your rooms and if there's  under 30mbps you can order a pod
I scanned the problem rooms and can't  find on the app anywhere to order. Do I have to spend hours on the phone listening to canned music on hold?
1 Reply
  • Hello AmandaCD
    Thanks for your first post and welcome to our community.
    Sorry to hear you are unable to order a pod through the App.
    Can we ask what speed test results you got from each problem room?
    Gareth_L
