on 08-08-2023 14:04
Why is the Virgin TV Ultra HD - Channel 175 - sent with a much lower sound level than normal HD or SD channels.
I have to increase the volume level by 50% to get a normal listening level.
Apart, of course, the adverts and announcements, which are at a normal, therefore LOUD level.
This applies to any recorded programmes as well
Answered! Go to Answer
on 04-11-2023 21:40
I had the same issue on mine as I run a Bose soundbar and Virgin UHD channel was always substantially lower than other channels.
Went into Settings, Audio and Dolby Digital, and changed from Dolby Digital to PCM to Dolby Digital. This vastly improved BUT there's a tiny sound sync issue, so I'll have to investigate further.
The sound settings on Virgin boxes are VERY poor by todays standards, considering what they're trying to deliver.
on 09-08-2023 09:58
Hey @pdfbt40,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you are having this, if it is only happening on one channel it could be due to the broadcast of said channel and how this is recorded, can you confirm if any other channels have the same issue?
Joe
on 09-08-2023 12:17
Only Virgin TV Ultra HD - Channel 175 seems to be permanently with a low sound level.
on 09-08-2023 13:44
Hey @pdfbt40,
Thanks for confirming this, with UHD channels they are recorded differently and thus the sound levels can vary compared to normal TV channels. Apologies for any issues this may cause you.
Joe
on 09-08-2023 15:43
Its not 'can vary' ! Its Always, in my experience a low volume.
Why is there not an admission that you get UHD vision with terrible audio all the time!!
on 09-08-2023 22:11
@pdfbt40 wrote:Why is the Virgin TV Ultra HD - Channel 175 - sent with a much lower sound level than normal HD or SD channels.
What's the sound like on Channel 999?
on 09-08-2023 22:25
Exactly the same as 175 !! Low volume compared to other HD & SD channels.
on 10-08-2023 08:59
We will raise this with the relevant team to be looked into.
Rob
on 10-08-2023 10:50
There have been some good documentaries on UHD recently and its irritating.
If in the future, channels go from HD to UHD it will be unacceptable to have to change channel with VM remote and then adjust volume with TV remote.
on 10-08-2023 10:56
We appreciate the frustration pbfbt40, this will be looked into and once we get an update we will provide it here.
Rob
