- japittsVery Insightful Person
You appear to have 2 separate issues.
1: Your 2 V6's don't connect to each other, both connect to your home-hub. How are each connected - are they wireless or Ethernet? For any wirelessly connected boxes, what's the signal strength? Home > Help & Settings > Settings > Network, check the top-right.
2: Any TV box that's freezing or restarting has a fault. Does this blurry picture affect live TV? OnDemand? Streaming? Recorded programmes? Are you able to post a picture or video of this problem?
- David_Bn
Thanks for your post on our Community Forums sylviah, and welcome back!
Sorry to hear of the issues you've been experiencing with the V6 boxes.
Can you please refer to the post from japitts, to give us a better idea of the fault and if there have been attempts to have this resolved on your end?
David_Bn
- sylviahTuning in
I will try one of the solutions you have suggested on the forum as I am having the exact same problems as one you have described. Will come back with answer or ask where to next
- sylviahTuning in
First I am wireless.
I have been into Home>Settings>Network and the results are as follows:-
Kitchen Network Status is between 55% and 60% (Good) and Channel - 6 195 mbps.
Lounge Network Status is 100% (Excellent) and Channel - 122 1300 mbps.
Even I can see there is a big difference but don't understand why, when I rang Virgin all I was told was both boxes are working OK there is no problem. Can you tell me in layman's terms why this is happening.
Lastly the Modem(Hub 5) is in the Lounge and I can not connect the kitchen via an ethernet cable.
- Kath_P
Hi sylviah,
Thanks for coming back to us on this one.
If the box is connected via WiFi then and the hub is not near it, this will explain why the signal level is less. The one next to the hub would likely have a better connection especially if this is connected via ethernet cable.
Depending on the WiFi in your property, there could be some interference which could mean it loses connection every so often. You can find help on how to improve WiFi here.
In terms of the picture freezing and being blurry, can you let us know if this is affecting the service across live TV / On Demand / Catch Up and Apps? Is it a mixture or across them all? If you can give us some more specifics on this, we can then help further.
Related Content
- 2 years ago
- 2 years ago
- 2 years ago
- 11 months ago
