FJHove's avatar
FJHove
3 years ago
Error msg re: remote control battery
I have the following error message on the screen - “Please replace the batteries in your remote control”.
I’ve done that (twice) and can’t get rid of the message when watching Netflix. I can get rid of it on live tv - it reappears when I change channel but pressing ‘TV’ gets rid of it.
I have checked all the cables, rebooted the box, repairs the remote, etc. TV is LG.
Obviously driving me insane - any suggestions?
  • PS have also reset Netflix account. This appears on all ‘apps’ - iPlayer, All4 etc.
    • Alex_RM's avatar
      Alex_RM
      Hi FJHove,
      Thanks for posting and welcome to our community 🙂
      Sorry to hear you're having some issues with the remote.
      Can you confirm if you're using rechargeable batteries?
      Let me know if this is still an issue and I can pop you over a private message.
      Alex_Rm
      • rbtwilliamson's avatar
        rbtwilliamson
        I'm having the same issue. New batteries, not rechargeable. Really annoying. Seems to happen more on apps.
  • Are you using rechargable batteries?
  • On our Virgin mini box remote we are getting the same message weekly and we DO NOT use rechargeable batteries. This only started a few months ago we never had this problem before. It's getting expensive keeping changing the batteries.
    Please advise of a solution?
    • roy247's avatar
      roy247
      Hero
      Don't replace the batteries until your 360 remote doesn't work.
    • Beth_G's avatar
      Beth_G
      Hi Spatuxedo,
      I'm sorry to hear you're also experiencing this issue, I appreciate it must be frustrating.
      Apologies if this is obvious, but does the error not disappear when you reboot the set top box (not just by putting it into standby)?
      If you do not have any recordings you wish to keep on your set top box, I'd recommend performing a factory reset to see if that resolves the issue.
      Let us know
  • Hi I too constantly receive the 'change your batteries' notification and the problem has only occurred since I was moved on to a 360 box - Is there a way to get back to a v6 box
    • Matthew_ML's avatar
      Matthew_ML
      Hey Numbstairway65, thank you for reaching out and I am so sorry to hear about this.
      Unfortunately once you are on the 360 there is no way you can do back to the V6 box.
      How often are you changing your batteries as it stands? Cheers
